1996 355 is one motor reverse rotation
Topic author
River rat
Vessel Info: 1996 355
Postby River rat » December 8th, 2013, 11:28 am
Does anyone know if the 96 355 has one reverse rotation motor?
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 29 times
Re: 1996 355 is one motor reverse rotation
Postby CYO Admin » December 8th, 2013, 11:51 am
Yes it does.
Topic author
River rat
Postby River rat » December 8th, 2013, 1:04 pm
Thank you I thought that by the ninetys they were done with the tans
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » December 9th, 2013, 12:35 pm
I believe it does not have a reverse rotation engine. The should both be standard rotation with the transmission changing the direction of the prop.
Kenny
T-Merc 350 Mag MPI (300hp)
CYO Admin
CYO Administrator
CYO Administrator
Postby CYO Admin » December 9th, 2013, 4:53 pm
Kenny is correct, and I stand corrected :)
Topic author
River rat
Postby River rat » December 11th, 2013, 11:16 am
Thanks I was hoping that was the case
glazingguru
Vessel Info: 1995 Carver 355 Aft Cabin
Postby glazingguru » January 31st, 2014, 7:57 am
I have a 1995 355 and the port motor is reverse rotation
MissWhit's
Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
Been thanked: 4 times
Postby MissWhit's » January 31st, 2014, 8:53 am
River Rat, You must be confused by this thread. "yes it does" and "No it does not" for your answer. Let me make it even more confusing HaHa...... In the mid 90's some boat manufactures started installing reverse rotation transmissions and initially it was depending upon inventory in the boat builders stock and vendor stock. Did all years of boats that were able to receive these transmissions get them? NO. This is due to the Vendor/distributor trying to purge stock of reverse rotation motors as they where offering price cuts to boat manufactures to eliminate inventory. One thread said his 1995 had a reverse motor on one side, but also the same boat same year built just a little later could have had both motors standard rotation with the transmissions performing the counter rotation. I do not know if your boat is winterized but the best way to find out the rotation is to look at the front of the engine at the Harmonic Dampener/balancer and during motor crank observe the rotation. Put a white chalk mark on the top of the HB/d and if it moves from the top to the right then it is a standard rotation. If the mark moves from the top to the left then it is reverse rotation. Have a good day. John
MissWhit's
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » January 31st, 2014, 9:31 am
There's another way to check without cranking the engines. Examine the shift linkages on the transmissions with both in neutral. Now place both shifters in forward and check the linkages again. If the shift arms moved the same direction then you have a counter rotating engine. If the shift arms moved in opposite directions (one forward, one back) then it is the transmission performing the counter rotation.
..Aaron
'99 404 CPMY
SeaDragon
