Window leaks
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 3 times
Re: Window leaks
Did u ever finish your window project? I am about to start mine and looking for your experience
Steve
- Seif911
- Captain
Re: Window leaks
I am finally getting to my window project. Yay! This far I have found that pulling the bottom board off will be a nightmare so I pulled the top board off, and pull the tracks out. Pretty interesting. There is a good bed of silicon but towards the edges the silicon is gone and a little rot. I am digging all of the rot out, and putting some sort of 'Git rot' on it, solidifying it. I think this will work out well, kind of exciting.
Next will be a bed of something, probably silicon, tempting to do 5200. Then put the tracks back in. Might even fill the weep holes with fiberglass resin and drill them back out, who knows.
Steve
- waybomb
- CYO Moderator
- Vessel Info: 1987 3697 Carver Mariner
1969 15' Glaspar / 1969 Johnson Electrmatic 85
1964 Barron Flat bottom drag boat
A couple of dinghies - Location: Saint Joseph and Trenton, MI
- Has thanked: 41 times
- Been thanked: 301 times
Re: Window leaks
1964 Barron Flatbottom with BBC Chevy
1969 Glaspar Avalon /1969 Johnson Electromatic 85
1988 Cougar Kevlar 46' with triple blown 572s
http://s4.beta.photobucket.com/user/waybomb/library/
- Seif911
- Captain
Re: Window leaks
I just broke some of the tracking for the windows. I just ordered all new tracking last night. I also found from another website, that part of the window problem is the top deck just drains straight down and overwhelms the windows. I just ordered EZE RV gutters. I will put that above the windows to route the water around them. It should help out quite a bit.
Steve
- waybomb
- CYO Moderator
Re: Window leaks
BoatLife is a bargain. Go shopping!
- Vessel Info: 1978 Santa Cruz 2866
Moosehead Lake, Maine
Re: Window leaks
JAB
- Seif911
- Captain
Re: Window leaks
Steve
- Seif911
- Captain
Re: Window leaks
My biggest suggestion is to drop the cabinet above the sink and remove the top board above the window to get the windows out. It is really pretty easy. If you had any thoughts about tinting, this is the time!
Steve
Re: Window leaks
I made some progress today. Will post pix later when I have more time.
Removing the top board is wayyyyy easier. The window double channels are trashed- partly age, partly damage from owners screwing things into the board (shades, etc).
I ordered some Beckson marine vinyl double channel. Hopefully will work.
Once it arrives(and I have a few sunny days in the forecast) I'll remove all windows and tracks and clean out the space. I gave 6 drain holes along the outer run. I hope to be able to caulk the inner board some more as well.
I'm optimistic that it will end up looking better, working smoother, and being drier!
But you know what they say about best laid plans........
JAB
- Seif911
- Captain
Re: Window leaks
Did you take the cabinets down over the sink? I can tell you I was not thrilled with my wife's idea, but man, she was right! What a difference. It just makes it seem larger and more open.
Steve
