Electrical
- Charleigh
- Vessel Info: 2005 Carver 56 voyager
- Has thanked: 3 times
Electrical
- Been thanked: 1113 times
Re: Electrical
Anything that's 240VAC won't, but you should be able to power 120VAC stuff, at least one side of the panel.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Electrical
If you have a twin 30 amp to 50 amp “Y” adapter, it will also work. I use this at the dock when a 50 amp is not available, such as my case at my home slip. Both of these 30 amp plugs must also be on a different phase for it will work. I have run into problems when travelling, trying to use my twin 30 amp to 50 amp adapter when the 30 amp posts are all on the same phase. I have to check a number of posts to fine one on a different phase to get 240.
One simple 30 amp to 50 amp will not work as the boat is only receiving 120 and not 240.
I hope this helps you out.
Greg
- Tireless
Re: Electrical
km1125 wrote:Source of the post What didn't work?
These boats must have 240 coming in or nothing will work not even one side of the panel.
Greg
Re: Electrical
https://www.marinco.com/en/p/RY504-2-30/Reverse-Y-Adapter-2-30A-125V-Males-to
- Charleigh
Re: Electrical
Re: Electrical
Re: Electrical
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Electrical
Re: Electrical
buster53 wrote:Source of the post Not an electrician but as I understand it, 240 comes into the boat and it is split into 2 x 120, but you have to have 240 to make it work.
If the incoming cord was only a 240 that might make sense. You'd need a transformer on board though, which a lot of boats don't have. If the incoming is 120/240 then it shouldn't be an issue.
The difference is the neutral connection. The 120/240 plug has a neutral connection but the 240 only does not. You'd need the transformer with a split secondary to establish the neutral (and bond it to ground). That would give you two 120's out of the 240.
