Charger noise
Topic author
Lastdive
Vessel Info: Carver 405
1998
Charger noise
Postby Lastdive » January 15th, 2014, 6:41 am
I have a 3bank C Charger , 3000 series that has a loud continuous hummm. Can this noise be stopped or can anyone recommend a good noise free charger. THANKS!
Own 1998 405
Home port: Knoxville, Tn.
Been thanked: 490 times
Re: Charger noise
Postby waybomb » January 15th, 2014, 7:10 pm
I installed a new ProMariner; makes no noise.
I also have Charles 3 bank that does not make noise, so I am guessing yours is failing.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Charger noise
Postby AaHubb » January 15th, 2014, 8:01 pm
An easy way to test it is to do a float test. Remove the charger from the boat and place it in water. If it fails to float then you need a new one. :-D
'99 404 CPMY
SeaDragon
DanM
Vessel Info: Carver 396
Been thanked: 35 times
Re: Charger noise
Postby DanM » January 17th, 2014, 4:19 pm
Charles has (or at least had) a fixed rate rebuild program for there chargers. Very through and much less money then replacing them. They were great to work with and it took about two weeks.
Dan
Dan
Carver 396
SugarSand Tango
Topic author
Lastdive
1998
Re: Charger noise
Postby Lastdive » February 6th, 2014, 7:30 am
Thanks all. Tried the float test and determined my charger was going bad. Purchased a Promariner.
Own 1998 405
