Hynautic H-50 helm leaking & unknown pump
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
- Merkinbrumsky
Re: Hynautic H-50 helm leaking & unknown pump
- Been thanked: 1113 times
There are threads on here where folks have rebuilt those helms, including the part numbers for the seals.
That other pump looks like the ones used on Bennett trim tabs. Usually there's a reservoir below it but I can't see that in your picture.
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
- Merkinbrumsky
It does have a reservoir underneath. I thought it was plumbed into the steering system bc of those thin black hydraulic hose’s, same as the helm. I need to investigate that further I ordered a seal kit for them helm but maybe I should have ordered 2 and do lower station at the same time.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Merkinbrumsky
Merkinbrumsky wrote:Source of the postkm1125 wrote:Source of the post
You are correct sir….trim tab pump it is..
The Hynautic systems are VERY easy to purge the air out of. You loosen the pressure screw on the ram, then crank the wheel over past the stop a bunch of times in each direction. All the air gets forced back to the reservoir then you can top of the fluid level. Because the system is pressurized, you just need to loosen one of the hoses at the helm to do the initial fill.
- Merkinbrumsky
- Merkinbrumsky
