replacing an old ice maker
- cpoint
- Has thanked: 208 times
- Been thanked: 28 times
Re: replacing an old ice maker
- Has thanked: 460 times
- Been thanked: 1711 times
cpoint wrote:Source of the post Thanks viper. I will investigate more next time out there. I was happy last time it was working on AC power, so I can shut of the DC power for refrigerator while not on boat. which seemed to work that way last week. But yesterday I was not able to power it up even when I switched the DC refrigerator switch (behind mirror) ON. I turned both receptacles on and no luck on AC power either. But I was in a rush and forgot to test to see if I had power on ports side receptacles . I will check maybe it is GFI.
It'll only be a GFI issue as a probably cause IF the refrigerator operates on the same circuit as other outlets. If it's a dedicated circuit and has its own breaker labeled as such, then this does not apply. Also unlikely the refrigerator outlet itself is GFI but you never know what's been done in the past.
- cpoint
- cpoint
AC panel has range, microwave, 2 receptacles, water heater, battery charger.
- cpoint
- mjk1040
- Been thanked: 243 times
cpoint wrote:Source of the post I think its fried. The GFI's are all on. Also under sink (next to refrigerator) found the plug where it is plugged into. There is power in the plug, so refrigerator is not getting power from AC and it is not getting from DC either.
While it likely is fried, don't assume anything. Just because there is power at the outlet doesn't mean it's getting to the board on the refrigerator. Same goes for the DC side. You must check for voltage at the board end to be sure. And if there is power there, see if you can open it up and look for a fuse. You might get lucky. It's an awful lot of money to spend without checking out all the possibilities first.
I go to bat for old refrigerators and the extra mile in diagnosis simply because like many things, they don't build them like they used to. I'm finding the newer units fail much sooner than their older counterparts. Mine and a lot of the 80s vintage and earlier units are still out there working after 40 years. The new ones on average won't come close by the failure rates I'm seeing. Having said that, if you spend a lot of time on the hook, you can't beat the efficiency of the newer builds and their lower power consumption which is very important when you're trying to conserve as much power as possible. They're also much quieter. Unfortunately mine is a power hog so it is on my bucket list to replace but I have no expectations that the new one will last as long.
Given the amount of sensitive AC electronics we're carrying like newer refrigerators, chargers, TVs, AC units, etc., I'm considering a shore power surge protection unit. Way too many spikes from marina supply and it's just a matter of time before these take out your equipment. It's probably the number one cause of board failures. Here is an example the units I'm talking about though I'm just starting the research. Something built into the shore power cord or the AC panel would be cool:
http://www.trci.net/products/surge-guard-marine
http://www.charlesindustries.com/main/ma_surge.html
- cpoint
Users browsing this forum: No registered users and 61 guests
