Lifters for 2001 Mercruiser 350 MPI
Dark Horse
Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI
Been thanked: 6 times
Postby Dark Horse » October 14th, 2022, 3:11 pm
I have 2 350 Mercruiser MPI in My 2001 350 mariner.
One of the motors has a lifter tick I just cant eliminate.
I am going to put a new set of lifters in it (cause I don't know which one is ticking)
Are a set a Chevy lifters for the same year 350 the same?
Or did Mercruiser use something different?
" The trouble with trouble is it usually starts out as fun!"
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
Has thanked: 598 times
Been thanked: 1281 times
Re: Lifters for 2001 Mercruiser 350 MPI
Postby bud37 » October 14th, 2022, 8:04 pm
Those should be roller lifters, not sure about if same as regular Gm, maybe, but I don't know who made the cams for them..........be sure it is not an injector/ exhaust leak/ sticky valve first, would be my advice unless you have eliminated those already.
Does the engine run fine and did the noise start right after spring start up ?
Been thanked: 601 times
Postby tomschauer » October 14th, 2022, 9:23 pm
They SHOULD be the same as any GM Vortech 350. As mentioned, it's a roller cam/ roller lifter engine.
Somewhere around 2001/2002 GM changed to the LS1 engine, those lifters will not work in your motor, so you want to make sure you get the proper ones.
Before all that, are you sure it's a lifter, not and exhaust leak or something else?
Hate to see you tear down the top end and have the same issue.
Dark Horse
Twin 350 MAG MPI
Postby Dark Horse » October 15th, 2022, 9:14 am
Its the starboard engine. Yes i starts right up and runs fine. But the ticking noise which sounds like a lifter tick to me, is there constantly. Haven't taken anything apart yet altho I am going to replace the exhaust manifolds shortly as well so figured a good time to replace the lifters. I don't think this engine has injectors as it has what looks like a carb but throttle body on it.
Hoplite808
Vessel Info: 1988 Carver 3227 Convertible
Been thanked: 8 times
Postby Hoplite808 » October 15th, 2022, 10:37 am
Darkhorse, MPI means Multi Port Injection so it is most definitely injected. The lifters are about $150 each so I’d take the time to figure which one is ticking. Usually with a roller lifter if it’s giving a really loud tick it’s most likely the roller collapsed and it’s grinding the cam away like a hyperactive kid on the class pencil sharpener.
https://www.wholesalemarine.com/mercury ... t1-lifter/
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » October 15th, 2022, 11:21 am
Also, have you tried to do a cleaner in there? I wouldn't leave it in there long, or do a lot of heavy-load running with it, but a few cycles and an oil change might make the issue go away. It won't repair a bad part but if it's just some debris or crud causing the problem it'd be a much easier solution than a teardown and the accompanying risks of causing other issues.
MyPleasure
Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
Been thanked: 21 times
Postby MyPleasure » April 4th, 2023, 8:32 pm
There’s a product called Sea Foam out that a mechanic I know raved about. You might want to look into that. Have you heard of this product Viper?
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Has thanked: 468 times
Been thanked: 1765 times
Postby Viper » April 5th, 2023, 6:50 am
Ya I've heard of Sea Foam, it's been around for a while and is a popular product. In certain circumstances they have their place but I'm not a big fan of most additives, I've always found most of them to be a whole lot of marketing hype and not actually provide meaningful results. I suppose they are a cheap alternative worth trying first on the chance that a symptom is just on the edge but I wouldn't put all my faith in them.
