Salon Light Replacement
- bobfino
- Vessel Info: 2005 Carver 396
- Been thanked: 2 times
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Salon Light Replacement
T-Merc 350 Mag MPI (300hp)
MissWhit's
- Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
- Been thanked: 4 times
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
- bobfino
Steamboat Willie
- Vessel Info: 1997 Carver 325 Aft Cabin
Nightmare
- Ramsport47
MissWhit's
Port: EYC Marina
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
MissWhit's wrote:Also get rid of those 10 watt Halogen bulbs as the heat is what is killing the light assemblies. Look at Marinebeam.com for replacement LED inserts. The bi-pin lamp you use in your fixtures is called a G4 Bi-Pin. Dump them and be forever free of hassles with your lights. I just upgraded my 2001 406 which had 20 of these G4 Halogens with an insert that comes on RED at first then you can switch them to WHITE by toggling the on/off switch. The amount of current I use now to run these lights is very little and no heat. My master bath had 4 lights in it alone, Salon had 6. What a difference. There are cheaper priced LED out there but they are not CONSTANT CURRENT DESIGN as they use series resistors to control the current. Do not get fooled by cheaper products. I do not endorse any manufacture but state the one above as this is who I purchased from. John
John,
Just to be clear. You used an LED insert and did not replace the whole fixture.
Fraser
MissWhit's
Port: EYC Marina
- feeez
Thanks for your tips
Fraser
Georgian Bay, Ontario Canada
2001 350 Mariner twin 350 MAG MPI
Users browsing this forum: No registered users and 189 guests
