Cutlass bearing replacement determination - 1984 Mariner 3697
rictamily
Vessel Info: 1984 mariner 3697
Has thanked: 14 times
Been thanked: 2 times
Postby rictamily » January 2nd, 2023, 8:51 pm
Hi,
My prop shaft is 1 ⅜ diameter. I have the boat on blocks so wanting to do maintenance while on the hard. The props are removed and when shaking prop shafts there is movement...movement enough to make a slight clunking sound when emphasized. Is there a certain tolerance?
Also, is the process of replacement just a cutlass bearing-removing tool to remove and replace? Or are other calibration methods required?
Been thanked: 1310 times
Re: Cutlass bearing replacement determination - 1984 Mariner 3697
Postby bud37 » January 3rd, 2023, 4:46 pm
Here is a quick reference i came across.......can't specifically answer your clearance question as I don't know....
https://www.pacificmarine.net/engineeri ... arance.htm
rictamily
Postby rictamily » February 8th, 2023, 8:19 pm
Thank you so much for your time.
