Water Tank Plumbing
Dpoelstra
Topic author - Scurvy Dog
Water Tank Plumbing
My starboard tank was disconnected at some point for some work on that engine. The question is, how are these tanks plumbed and connected together? It almost looks like the inlet Ys off to fill both tanks, and the draw from the pump also is Y'd to draw from both tanks???? Am I wrong?
Any help in how this is supposed to be plumbed would be helpful.
"Brown Eyed Girl"
1981 Carver 3007 30ft. Aft Cabin
Huntington Harbour, Ca
"But why's the rum gone....?"
- waybomb
- CYO Moderator
- Been thanked: 489 times
Re: Water Tank Plumbing
Have you attempted to trace the lines back from the faucets to see where the get their supply from? You may need a flashlight and one of those mirrors that extend out.
As for the fill, I would guess there would be just one. My current boat has three tanks it appears, and only one fill.
But since my first Carver, I don't use on board water. I hook it up to dock water. The water goes bad in the tanks and if you don't stay on top of it and use it often, it starts smelling weird, which means something must be growing. Plus, at 7 pounds or so a gallon, no need to be dragging 500-700 pounds more weight around.
Dpoelstra
If your water smells bad, add a bit of Clorox bleach...just a bit...like a tablespoon for 30 gallons. Run all the faucets wide open until you can detect a little bleach smell.
Gets all the yuckies out of the tank and lines.
"Brown Eyed Girl"
Dpoelstra
Thoughts?
"Brown Eyed Girl"
- waybomb
- CYO Moderator
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
I think the difficult part would be changing to inch and a half fittings for the sanitary hose's. Your best bet would be to talk to a marine sanitation systems store in your area. I know of one in Seattle but I would think you could find one closer.SeaDragon
Dpoelstra
Now if anyone has a 3007 aft that can shed some light on how it is plumbed, that would be great.
"Brown Eyed Girl"
Users browsing this forum: No registered users and 69 guests
