Steering not working on the 3207
- waybomb
- CYO Moderator
- Has thanked: 66 times
- Been thanked: 482 times
Re: Steering not working on the 3207
There should not be an overflow. The system is a completely closed system. There must be some sort of leak. It won't get better. You need to find that leak.
In a hynautic system, the wheel should turn and turn, no stop; it will feedback a higher resistance to turning once the rudder is deadheaded and the relief valve opens. I suspect you have a bad or stuck relief valve on the starboard side. The relief valve is in the block mounted on the bottom of the reservoir.
jwrape
Topic author - Deck Hand
- Vessel Info: 79' Carver 28 Mariner Twin Pleasurecraft 302's (For Sale $12,300)
85' Carver 3207 Aft with Mercury 5.7L - Been thanked: 1 time
waybomb wrote:I suspect you have two issues.
Good to know, I will check it out and see when I'm out on Monday
nolacarver
- Vessel Info: 1979 33' carver
New Orleans, LA
Cuyose
- Vessel Info: 1985 Carver Voyager 28
Users browsing this forum: No registered users and 63 guests
