Bilge Fans 86 Carver Aft Cabin
- jim&jerrie
- Vessel Info: 1986 Carver Aft Cabin
- Has thanked: 1 time
I disconnected the power and ground wires to the fans and checked voltage while switching both bilge fan switches independently on. With either switch on the wire leads to the bilge fans have 12+ volts.
I then thought, OK maybe the fans both stopped working. I connected each fan to one of the batteries in the boat and both immediately worked.
Next, I connected the fans back up and tried each switch. Fans did NOT work. Ok, scratching my head a little now.
With the fans connected I then checked the voltage again while independently turning on each fan switch. ZERO volts with the fans connected???
Why would I get a good volt reading with the fans disconnected but ZERO volts with the fans connected?
Is this a relay issue or possibly a ground issue?
I have a wiring diagram but I'm unsure what the relays look like or where I can find the common ground location for the bilge fans. (It appears that several components ground to a central location)
Also, the 12 volt panel has a switch to cut bilge fan power, but this was in the on position while performing my checks.
Any and all help is greatly appreciated!
- Been thanked: 1113 times
Re: Bilge Fans 86 Carver Aft Cabin
Cut the problem in half. Run a ground wire directly to the motor and see if that solves the problem (which tells you the high resistance connection in in the ground circuit), or start working on the positive side.
And the "switch" on the 12 volt panel is a circuit breaker to provide power to the blowers. It should be on all the time.
There are no relays in that circuit, just two separate switches that both go to the "hot" side of the blowers.
I think all the wiring from the blowers goes to the lower station first, so just start there with your troubleshooting (looking for the ground and the connection at the switch). Once you get that station working, the bridge should work OK too, or you can troubleshoot that separately.
- jim&jerrie
- Has thanked: 603 times
- Been thanked: 1311 times
