Who to call for carver parts
Lucvan
Vessel Info: Carver 444 cockpit 2002
Postby Lucvan » May 24th, 2023, 12:24 pm
Hi to all, my name is Luc and new to this forum.
I have a 2002 carver 444 cockpit motor yacht and looking for a new sender for the fresh water tank.
Who do I call to get the correct model number?
Re: Who to call for carver parts
Postby g36 » May 24th, 2023, 4:30 pm
Welcome aboard. Carver didn't make this, so if you could post a picture or if it has any branding we can help with where to possibly get parts for it.
Postby Viper » May 24th, 2023, 7:56 pm
Welcome to the neighbourhood. As g36 said, most items weren't manufactured by Carver but by 3rd party suppliers. They used several different senders over the years, the trick is determining which one you have. Ya a pic would really help. Look at the gauge and see if there is a brand name on it.
Postby tomschauer » May 24th, 2023, 9:58 pm
http://www.centroidproducts.com/
It is most likely made by centroid.
JimN
Vessel Info: '89 Carver Santego 38
Been thanked: 3 times
Postby JimN » May 25th, 2023, 10:46 am
Part number should be on the top of the sensor, in the black plastic if it doesn't have a label. Might be on the side, but it will be on the part. If it's just inaccurate, make sure the water is clean and doesn't have anything in it that's not water- these are very sensitive to contaminants, whether used for gas, water, whatever.
Lucvan
Postby Lucvan » May 25th, 2023, 2:20 pm
Thanks for your info. On top of the sensor it says:
WUF19 and T090.
Brazil
Hugo
Been thanked: 23 times
Postby Hugo » May 25th, 2023, 8:58 pm
I replaced this on an 04 444 in 2016. More than likely yours is the same. Take a look at the picture, pull it out and measure. The one I ordered was 19” long. It was the SSL/SSL sender 5 hole pattern.
The company used to be called wemausa but it’s this now. Looking at your part I believe you want the SSL in 19”
https://kus-usa.com/product-tag/electric-reed-switch/
