Intake Hose leak??
- tricountytrail
- Vessel Info: 1989 Carver 2557 twin 180/3.7LX Alpha One drives
- Has thanked: 1 time
Intake Hose leak??
Checked bellows before purchase looked ok newer all intact, During seatrail ran great shifted great. when we got back to dock was letting it idle and starboard engine was running hot. After I got it home I as was reinspecting and found starboard hose from bellhousing to gimbal housing is kinked and looks like it has a hole.
Looking for advise as to if I can change out hose be removing drive then bellhousing? Will I be able to change hose with out removing drive shaft and exhaust bellows.
Any thought or help would be appreciated.
- tricountytrail
Re: Intake Hose leak??
I will check on hose and compare flow to other drive.
Drop it in the water and hopefully be all set!!!
