Kohler generator for dummies, questions
smcguckin27
Vessel Info: 2004 Carver 360 Sport Sedan.
Has thanked: 8 times
Been thanked: 7 times
Re: Kohler generator for dummies, questions
Postby smcguckin27 » July 6th, 2018, 11:09 am
One other thing to consider. On our Kohler 7KW I had a wierd issue where the tips of the zinc in the heat exchanger were breaking off (I suspect from the waterjet of the raw water flow they were wearing in the centers faster than on the tip). The tips then wound up in the elbows where the raw water is injected into the exhaust which of course reduced water flow and then it would shutdown on overheat. Once cleaned up I then cut each zinc in half so that could not happen again and the thing ran great for years after.
Has thanked: 247 times
Been thanked: 381 times
Postby bud37 » July 6th, 2018, 11:33 am
Good catch on the zincs........ :approve:
buster53
Vessel Info: Carver 356
Been thanked: 47 times
Postby buster53 » July 13th, 2018, 3:45 pm
buster53 wrote:Ok, I have a Kohler 7.3E-CB. Yesterday, I ran the unit for about 30 minutes, mostly running one AC unit and both AC units for 5-10 minutes.
Genset shut down. Restarted and ran for a minute or two before shutting down again. This happened several times and would only run a minute or so. After 5-6 restarts, it would only run for a few seconds before shutting down. Just bought this boat in March and haven't had any problems until today.
I checked to make sure my oil level was good. What's next...replace fuel filter maybe? Any other suggestions?
Ok, had a tech guy look at my genset and he tells me the fuel pump is shot. He suggested I order the pump and when it comes in, he will install it.
Where's a good place to order Kohler parts?
Return to “Electrical”
Users browsing this forum: No registered users and 1 guest
