2000 374 voyager water heater tank
- 333
- Vessel Info: 2000 carver 374 voyager
- Has thanked: 602 times
- Been thanked: 1311 times
Re: 2000 374 voyager water heater tank
Does the tank still function as a water heater, but you are concerned with the lines from the engine to heater side ?
- warren.corbin
- Vessel Info: 1999 Voyager 450
- Has thanked: 1 time
Or I'm reading this wrong and it's the fresh water lines that have been removed. If that's the case, either someone forgot to reconnect them after winterizing, or the tank is leaking. Take a look at the empty ports, the fresh water ports on the tank without fittings will be female threaded holes, and the coolant exchanger ports will be two pipes sticking out with nipples for clamping on engine coolant lines.
When you turn on the breaker for the tank, do you eventually get hot water?
- 333
- 333
