2000 374 carver gear oil
- 333
- Vessel Info: 2000 carver 374 voyager
- Been thanked: 1113 times
Re: 2000 374 carver gear oil
- Has thanked: 602 times
- Been thanked: 1311 times
333 wrote:Source of the post Carver model 374 with cummins 330 hp diesel engines. What oil is used in transmission gear box. It smells like engine oil differently not gear oil [ 80w90 ]. I have checked through manual that came with the boat but doesn't mention grade of just that it needs to be checked. I would be grateful if someone on here could answer this question. Thanks
My advice , get the serial number and model number off the trans I.D. plate and e mail the manufacturer to ask what oil/fluid they installed from new around 2000. They are straight drives , correct?
To add to the above.....it is important to use the correct compatible fluids in these applications. Over time builders change their specs and shaft seal etc materials which can be affected by different fluids. Some fluids have seal conditioners etc to help performance to stop leaks, perhaps a different viscosity etc.
That is the reason to get what the manufacturer of the unit recommends for those year builds.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Kyle
2002 Carver 396
- 333
Thanks all for the help
Users browsing this forum: No registered users and 50 guests
