1987 Carver Mariner Project Boat - galley pole question
lz33w7
Vessel Info: 1987 Carver Mariner 3297
Postby lz33w7 » June 12th, 2025, 9:57 am
Hello friends,
This is my first boat ever. Does anyone know of this is a “support” pole as I’d like to take it out….
Kindly,
v/r,
Stephen
Has thanked: 603 times
Re: 1987 Carver Mariner Project Boat - galley pole question
Postby bud37 » June 12th, 2025, 10:27 am
Is there any wiring/cables etc in there ?
lz33w7
Postby lz33w7 » June 12th, 2025, 10:33 am
Not sure about that…
I’ve seen newer boats, but same model without that pole…..
Kindly,
v/r,
Stephen
Been thanked: 413 times
Postby Cooler » June 12th, 2025, 12:14 pm
It was an additional support feature to the floor of the bridge. Provided extra strength to support cabinets hanging in galley, as well as where passengers would walk and sit on the bridge. Not 100% necessary, but I wouldn't pull it out, considering the age of the vessel. It's not getting any younger, and you may regret the potential sagging effect. Good luck. 8-) er
Been thanked: 491 times
Postby waybomb » June 12th, 2025, 2:21 pm
It is a support pole.
There are no wires in it.
I had to shorten mine when I installed the granite counter tops.
Postby km1125 » June 12th, 2025, 5:58 pm
I would definitely not pull it out. I had three like that in my 3607. I think you'd get a lot of "flex' in the sole of the bridge.
