engine room blower
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
engine room blower
Postby Agriman » June 18th, 2025, 2:13 pm
I noticed my port side blower was not working, so I gave it a rap and it started. Shut off and tried again and it didn't start again until tapped again. My question is can it be lubricated or is it toast?
Has thanked: 603 times
Re: engine room blower
Postby bud37 » June 18th, 2025, 2:44 pm
My personal opinion would be, replace it with new. Let me just say ,....if you did get some way to lube it, it is old and damaged so the possibility of it overheating and starting a fire or who knows is not worth it, considering the needed personal safety this units affords.
I think you have may have 2 of them in that model, perhaps consider changing out both while down there.
Postby km1125 » June 18th, 2025, 3:05 pm
I would recommend replacing too. Most don't have serviceable bearings and it's probably not just a lubrication that's going awry.
Postby Viper » June 18th, 2025, 3:59 pm
If it's your typical in-line blower, I say replace it. If it's the upgraded squirrel-cage type, some higher end units are serviceable.
Agriman
Postby Agriman » June 22nd, 2025, 2:37 pm
Thanks guys, I took your advice and installed a replacement.
Users browsing this forum: No registered users and 40 guests
