New To The Forum
Ric
Vessel Info: 1995 Carver 440 Aft Cabin Twin Cat 3116 propulsion.
New To The Forum
Postby Ric » August 24th, 2025, 12:14 pm
Hell, I’m new to any forum. I apologize in advance if I post something in the wrong place.
Occupation: Retired
Boat: 1995 Carver 440 Aft Cabin
Propulsion: 2ea Caterpillar 3116
Set to close by mid-September.
The vessel is turnkey, but I'm a little dubious of Cat marine engines. Thoughts?
I look forward to learning from you guys.
Thanks!!
Been thanked: 490 times
Re: New To The Forum
Postby waybomb » August 24th, 2025, 3:44 pm
Welcome aboard!
Catch up on all maintenence on those engines. Then keep up with it. They will be fine if you do the maintenence as scheduled.
If you are concerned. Then get the driveline surveyed as well.
Ric
Postby Ric » August 24th, 2025, 4:57 pm
Thanks, I'm having the pre-purchase survey done tomorrow with all the oils analyzed, but still a little dubious about the 3116s. Fingers crossed.
Users browsing this forum: No registered users and 364 guests
