Glendinning Power Cables
- bobfino
- Vessel Info: 2005 Carver 396
- Been thanked: 2 times
On my 2005 396MY I have the Glendinning power cables that decide to work when they want to. I can go weeks and have not problem and then one day I hit the switch and they do not go in or out. Leave them over night and they work again. The problem I see is that there is no access to them unless I take the aft stateroom night stand apart which I have not done yet. However, before I do that I was told there might be a switch that automatically stops the cable once it retracts (in case you are not manning the switch I guess) and this switch might get stuck and then correct it self some how. Looking for some help on both accessing the cables master and if this switch really exists. Thanks for any input
- rrueckl
- Vessel Info: Carver 39MY 2005
Re: Glendinning Power Cables
Just checking to see if you found the answer to your question or have since solved it. I have the 2005 39MY without the Cablemaster unit, but am looking to install one. It does appear to be in a very difficult place to get and just wondering if you were able to access it and if so, how difficult it was to get to. Thank you.
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
T-Merc 350 Mag MPI (300hp)
- rrueckl
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- bobfino
SHEMP
- Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht. - Location: Toronto Ontario Canada
- Been thanked: 4 times
I have a 456 and my Cablemaster is accessed through a panel in the aft stateroom port side locker. About 8 screws to remove and the Cablemaster is right there. I think if you need to check limit switches and wiring connections, you will find ample room . Now , in your case the night stand might be a little more work but I have found that Carver has made access to important equipment quite easy. Is your Bed and Night stand on the Port side corner of your aft? It looks like the Aft Steps are the same on many larger Carver models , port side.Take your time and you will find easy access . I normally allow a minimum of two hours for jobs such as this . Victor
Users browsing this forum: No registered users and 60 guests
