Carver 440 exhaust problem
Topic author
peterrenton
Vessel Info: Carver 440 1996
Postby peterrenton » August 23rd, 2014, 1:20 pm
I have Cummins 475 hp engines. The exhaust is terminated through 45 degree elbows at the transom and out past the swim platform. My probelm is a tremendous amount of sooting that is accumulating both over my dinghy mounted at the rear of the swim platform and all over the stern of the boat. Has anyone ever tried extending the exhaust pipes to the rear edge of the swim platform to stop this. The engines are in tune with no issues. Any suggestions would be welcomed.
Ramsport47
Been thanked: 59 times
Re: Carver 440 exhaust problem
Postby Ramsport47 » August 25th, 2014, 6:19 am
The problem isn't the exhaust location, but the fuel you are using. It is recommended that you use a diesel fuel additive which eliminates or lessens the sooting of the exhaust. Try that first, it'll save you a lot of money on mods and cleaning
Kenny
T-Merc 350 Mag MPI (300hp)
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » August 25th, 2014, 7:33 pm
Keep in mind that with diesels - especially turbo/inter cooled diesels, the exhaust diameter and length are designed, not just plumbed. In other words, running a longer pipe, different diameter etc - may have both short and long term impacts on your engines. Unlike gassers, "uncorking" the exhaust is a negative.
Try a better grade fuel or a fuel additive as mentioned. It may take a while to clean up, but it will definitely clean up. Also, spin your engines up to WOT and then back off 10% - will help keep your engines clean. I do this for short bursts once a week in season.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Topic author
peterrenton
Postby peterrenton » September 7th, 2014, 12:08 pm
Thanks for the input. I will see what I can find for a diesel additive that will help with the problem.
SomersDaze
Vessel Info: 2004 570 Voyager Pilothouse
Postby SomersDaze » September 10th, 2014, 12:41 pm
We just cleared up a similar problem on our Volvo 675s on our 570. After many other checks we just put in new turbos because they weren't getting the proper air. Spent the day on the water yesterday for our first outing with them and are finally pleased to say we were without soot for the first time in a long time.
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » September 10th, 2014, 3:14 pm
Was there many hours on your Volvos? That's bizarre that BOTH turbos were bad - beyond bizarre when you look at the reliability of the Volvo design.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
SomersDaze
Postby SomersDaze » September 11th, 2014, 10:31 am
No. Only 550... It was bizarre but we had several mechanics look at them and perform every other option to no avail. The boat was hardly used the 10 years before we took it. Thus little maintenance was done. The lack of use has been the brunt of all our issues. The entire aft... Entire ... would be covered in soot even more so when the wind was behind us. But it is fixed and we are thrilled!
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » September 11th, 2014, 5:53 pm
Wow, still shocked. My 2001 506 had only 290hrs on it when I got it this winter, the previous owner had passed away and it was left to his elderly parents 2006 - so the hours were delivery hours, spring run up and winterization. It was never used after his demise, but I have no soot from my Volvos. But, they maintained it with an open cheque book. I am up to 430 now with no issues.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
jnick
Vessel Info: 2000 Voyager 450
Twin Volvo 460
Postby jnick » September 21st, 2014, 12:47 am
What additive have you been using for a cleaner burn? I just recently started having this same soot issue. Funny it started after taking on about 400 gallons of fuel from our local and reputable dealer.
avtech001
Vessel Info: 2001 Carver 506
Twin Cummings QSM-11 640 HP
Postby avtech001 » October 5th, 2014, 6:31 pm
Just as a side note .....I have seen boaters pull fuel off the bottom of the tank that for some reason had something in it that caused the above described issue, a lot of sooting from both engines
Users browsing this forum: No registered users and 137 guests
