Bilge pump
- True North
- Vessel Info: 1998 405 carver aft
Bilge pump
Thanks.
- Been thanked: 653 times
Re: Bilge pump
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Bilge pump
Re: Bilge pump
g36 wrote:Source of the post In my 405 (same boat different year) the engine room bilge pump is under the genset and not easiest to access. You may not see it unless you get low and look forward. I have a section of panel that I can lift out without disturbing my batteries that gives me access there.
G, is your genny battery under the genny too like the 355s?
- True North
Re: Bilge pump
Re: Bilge pump
Viper wrote:g36 wrote:Source of the post In my 405 (same boat different year) the engine room bilge pump is under the genset and not easiest to access. You may not see it unless you get low and look forward. I have a section of panel that I can lift out without disturbing my batteries that gives me access there.
No it's battery is not under the genset. It's sitting in between the stringers on the same level as my start and house bank batteries are. I ve got a couple feet on the lower level shelf which is made up of 2 individual sections and butts up to the genset that i can pull up to visually see the bilge then there's a second shelf over the batteries on top of the stringers. Ive been a few 355"s i have a couple friends that have those. There is way more room in my 405 I can get in the engine bay easily and have plenty of room midship and forward of the engines to sit and do any thing needed. I'm 63 and very thankful for the access I have.
Users browsing this forum: No registered users and 153 guests
