1989 Mercruiser 3.7L Thermostat question?
tricountytrail
Vessel Info: 1989 Carver 2557 twin 180/3.7LX Alpha One drives
Postby tricountytrail » September 10th, 2014, 2:32 am
My twin engine Carver runs about 120 130 degrees.
Boat ran great all summer, I believe the previous owner (I just bought at beginning of year) has removed the thermostats. Should I replace them with original 160 degree ones or leave as is?
Ramsport47
Been thanked: 59 times
Re: 1989 Mercruiser 3.7L Thermostat question?
Postby Ramsport47 » September 10th, 2014, 6:29 am
I would install them with the original 160 degree stats. The engine is designed to run at 160 - 170 degrees and you won't be burning fuel efficiently if it's not getting up to the recommended temperature. Keep in mind, you will lose some coolant when you replace the stat as it is in the manifold
Kenny
T-Merc 350 Mag MPI (300hp)
tricountytrail
Postby tricountytrail » September 14th, 2014, 2:40 pm
I did replace both out drive impellers when I got it They were defiantly bad, maybe this is why he removed them. He was a "Diesel mechanic". I will return them to stock.
