I get an alarm from the electric shift throttle unit when powering up the bridge electronics. The alarm can be silenced by pressing the "select" button on the throttle mount but the LEDs for FWD, Neutral and REV continue to flash. The shift & throttles work but this is clearly not normal operation. Has anyone else experienced this?
It seems from my Google search that this may be a communication issue that can be related to the powering up sequence?
I've tried cycling the switches on the servo units in the engine room (electric shift to manual shift) which has worked in the past, but no joy this time.
Thx
Electric Shift - Carver 396
- Andy2159
- Vessel Info: Carver 396 MY
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 154 times
- Been thanked: 150 times
Re: Electric Shift - Carver 396
What engines do you have and do you have the brand/model for your shifter? Mine are Cummins diesels and everything is mechanical so I'm not much help, but if you could give a little more info about your setup it might help. Good luck and welcome!!
Kyle
Kyle
MV Verity
2002 Carver 396
2002 Carver 396
- Been thanked: 1117 times
Can you elaborate/clarify what's going on? What "bridge electronics" are you powering up? (radar?radio?plotter?) Are the engines already running fine when you're doing this and THEN you get the alarm?
