RPM VS Knots
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: RPM VS Knots
Your previous post to your "last post" backed up exactly what I said - I even reiterated the simple calculation for you so you could understand the image that YOU posted.
I'll re-reiterate for you, one last time:
"we recommend a cruising speed of at least 200RPMs less than wide open throttle" (that's what you posted)
2300RPM x 10% = 230RPM
2300 - 230 = 2070RPM
2300RPM - 2070RPM = 230RPM
EITHER WAY, ITS "at least 200 RPMS less than wide open throttle" AS PER YOUR POSTED DOCUMENTATION.
I don't need to post documentation, you are arguing it for me.
I am not entering into a war of wits with the unarmed.
Thanks for proving my data so I don't have to.
You are right though, every website does have one. You proved that fact also.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
Re: RPM VS Knots
"we recommend a cruising speed of at least 200RPMs less than wide open throttle" is saying exactly what I'm telling you not what you're saying.
The key phrase here is "at least", you're not understanding what this says.
Read it about 50 times and get someone that understands English to interpret that for you.
That is saying exactly what I'm telling you, cruise at a speed of "at least" 200 rpm less, in other words the lower you go the better, not the other way around. At least 200 rpm is saying 300, 400, 500 rpm off of WOT is okay, not the way you're reading it.
The way you're interpreting that the phrase "at least" would imply that cruising at 100rpm off the top or WOT is okay, no manufacture is going to rate a high performance diesel at those numbers. Engines that are run at these power levels are de-rated to meet that duty cycle but you clearly don't understand what duty cycle is either.
Before you reply with more garbage to fill your EGO actually read what I wrote, you're not reading it, you just want to be right no matter what. It's okay to be wrong in life my friend that's how we learn.
- Lyndon670
Re: RPM VS Knots
I wasn't going post this, but Hugo wasn't going to come back either....
From my Volvo Manual:
Copied from Volvo D9 Manual ......
Pg71
Operation
Cruising speed
Avoid operation at full throttle, for best fuel economy. We recommend a cruising speed which is at least 10% below the
maximum engine speed at full speed (full throttle). The maximum
engine speed will vary due to propeller choice, load and sea conditions, but it should be in the full throttle range.
If the engine does not reach the full throttle range, this could
be caused by a number of factors which are noted in the
“Fault tracing” chapter. If the engine speed exceeds the full
throttle range, select a coarser pitch propeller. Ask your
Volvo Penta dealer for advice.
(They are going to change the last line to read "Ask your Volvo Penta dealer for advice - or Hugo)
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
- Hugo
Re: RPM VS Knots
"at least 10% below the maximum engine speed at full speed (full throttle)" Means don't cruise over 90% WOT but it does not mean you have to cruise at 90% of WOT!!!! It's quite the contrary; they're trying to tell you not to exceed a cruise speed of 10% off of WOT!. Less rpm is better is what they're saying.
I've beaten this horse dead. You need to get someone else to help you understand this. Print it and take it to your Volvo tech or something, you're not understanding what I'm saying or what you're reading. For the last time I will tell you that it's the opposite of what you think.
Volvo needs to reword that so that people like you understand it...
No, they won't ask Hugo because Lyndon's approach is more profitable - more piston meltdowns and shorter engine life. After all Volvo wants to sell and repair engines...
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
Re: RPM VS Knots
Take it down a notch.
- PhilH
- Vessel Info: Carver Californian 45 M/Y, 1990 Cat 3208 diesels
- Has thanked: 5 times
- Been thanked: 3 times
- Contact:
Re: RPM VS Knots
- Kby
- Vessel Info: Carver 444
2003
VOLVO TAMD 63 twin
Re: RPM VS Knots
I need your help I have carver 444 with volvo penta tamd 63p.
My issue is speed the max speed that the boat runs currently is 10 miles with an RPM 2100 I noticed that there is a lot of black and grey smoke while running.
Is there anyway to increase the speed or what should i do in this case.
- Kby
2003
VOLVO TAMD 63 twin
Re: RPM VS Knots
- Been thanked: 1111 times
Re: RPM VS Knots
How clean are the engine filters?
I'm sure that boat will do well over 10, but you have to figure out if the boat is loading down the engines or if the engines are having trouble developing power.
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: RPM VS Knots
Users browsing this forum: No registered users and 89 guests
