bad transmission?
iceman3500
Vessel Info: 1987 Carver 3207
bad transmission?
Postby iceman3500 » October 23rd, 2014, 9:03 pm
So I cruised out to our local large marina to get my tanks pumped out before winter. Pulling up to the dock, I idled back to neutral but was still going forward too fast. Threw both engines into reverse but wasn't slowing. Gave it some gas and the starboard engine stayed in forward and sped up while to port went into reverse. Needless to say, way too close to the pier and the 3207 bumped into the end of the dock as it spun sideways to the starboard side. Bounced of the floating docks and back into the open water. The marina owner is yelling " my docks " and I'm yelling " my boat is stuck in gear". Line everything back up and try again but still the starboard engine will not come out of forward gear. I threw it in reverse again and tried the throttle but it only went faster in forward again. Luckily was stopped by a wooden retaining wall. Needless to say, the most humbling and humiliating docking experience of my life. Not sure of the damage until I get it pulled out tomorrow.
The mechanic comes down and finds that the shifter cable has popped out of the retainer. We think this an easy fix until we hook everything back up and start the starboard engine only to find that it immediately goes into and stays in forward. If we pulled it back into reverse, the motor would die. The shifter cable is working and you can see the lever work from forward, into neutral , and into reverse, all this occurs while the motor is off. The mechanic says the tranny is having issues.
Even after 6 or 7 rum and cokes with my buddy, who knows boats, I'm at rock bottom. What is involved in working on a 1987 3207 transmission? The guys at the marina are saying they may write off the boat due to the gel coat damage, although it doesn't look that bad to me and definitely does not affect the seaworthiness. Will have to get some estimates once everything is on dry land.
There are lots of woulda, coulda, shoulda answers to what happened, and believe me I've put myself through all of them, but I didn't see this coming and don't know what I would have done different.
I'm just looking for answers, if any body has them, about the transmission
Has thanked: 64 times
Been thanked: 481 times
Re: bad transmission?
Postby waybomb » October 24th, 2014, 12:15 pm
Taking a trans out isn't / shouldn't be all that difficult.
Disconnect the prop shaft, the cables, hoses, drain the thing, remove it from the engine and its mounts.
There are places you can ship it to for repairs.
Can't advise on the gel coat. I would not trash a boat because of some cosmetic damage. If anything, clean up the hull, fix the dings, and Awl-Grip it.
Don't feel bad - I saw a guy in a 50 foot all-aluminum high powered diesel offshore boat have something stick in his transmission and tore off, litterally ripped off, the all-welded aluminum arch and destroying everything on top of it.
Nobody is hurt; all is well.
Washopay
Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers
Has thanked: 23 times
Been thanked: 5 times
Postby Washopay » October 25th, 2014, 10:52 pm
I have no advice other than there is likely not enough rum and coke in the WORLD to erase the memory of that experience. Good luck. Don't scrap her. :beergood:
colorpro fiberglass
Vessel Info: 1987 Carver 3207 Aft-cabin
Postby colorpro fiberglass » August 18th, 2015, 1:09 pm
I have the same problem, port motor stays in gear, dies when in reverse. What wasprognosis? Thanks,fglassman
JimHayes11
Vessel Info: 1984 3208 Carver Aft Cabin
Postby JimHayes11 » May 1st, 2016, 11:38 pm
Exact situation happened to us, (not hitting gas dock) but when I start the starboard engine and its in nuetral, the boat jumps forward. If I put it in reverse engine dies, any help or suggestions. What I have read, could be transmission, but not sure.
