Raymarine Sat-Dome Questions
Posted: June 8th, 2016, 2:00 pm
by Wayne162
I have a Ray Marine 45 STV Satellite dome from a previous owner already installed on my 405. The antenna unit powers up and tracks DTV at this time. I am trying to figure out what is needed to make the unit work at the TV's. I currently have DTV but may switch to Dish network for the boat use as I believe that Dish receives both analog and HD signals where DTV does not. I contacted DTV and it appears that you need a D12 or H24 receiver, but they want $100 plus a two year contract that they don't tell you about. Even if you purchase the units from a 3rd party provider, DTV still owns the unit. I am leaning toward Dish at this time and would like any direction available as I am not trying to re-invent the wheel. Just need to know what I need to ask for and if I have the vendor set the dish up at my home can I then install it on the boat. Thanks
Re: Raymarine Sat-Dome Questions
Posted: June 8th, 2016, 4:28 pm
by g36
I use dishnetwork at home and on the boat. Depending on where you live I live in tennessee will also dictate which sats you need to see in order to get all of the programming. I need to see 110,129 and 119. There is both hd and non hd channels . I have and use there vip211 receivers on the boat and at home but I have an intellion system so don't know of this receiver will work with the ray dome.. should be able to google the dome you have and find what is compatible with it my intellion will work with either i just have to input what provider and that sets up what it will look for. maybe I gave given some useful info
Posted: June 8th, 2016, 9:14 pm
by Wayne162
Thank you g36, its good to know you use it successfully. That gives me hope that I should be ok. My home port is Charleston, SC so were on the same latitude and it shouldn't be that different. I'll update the site when I am successful.
Posted: August 16th, 2016, 4:19 pm
by Wayne162
Contacted Raymarine about my 45 STV. I asked if I could use both DTV or Dish with my system as the ACU gives me either option. They told me to look-up the version within the ACU. It returned the following: Ant - S/W Ver:1.03 and ACU - S/W Ver 1.00. This information was provided and they told me that it appears to be a generation 1 antenna. I asked what do you mean appears? They should know right! Raymarine "believes" it will only work with DTV and not Dish but would not provide a yes or no. Is there anybody out their that knows about this unit and its compatibility. Google searches have not found the solution thus far to my questions. I would also like to know if the ACU can be upgraded or reprogrammed. Trying to get Raymarine on the phone is next to impossible. Thanks
