BNC Camera
Posted: February 27th, 2018, 8:04 pm
by SanJuanDreamer
My Garmin 741xs has a BNC connection for a camera.
The ones I've seen so for are about $400.
Has anyone used a less expensive camera while using the BNC connector on a MFD?
Re: BNC Camera
Posted: February 27th, 2018, 8:33 pm
by tomschauer
I have never used one on an mfd. However, a BNC input should be a generic video in. Buy a $49 camera with power supply at BJ's or Costco and try plugging it in without undoing the cables. My bet is it will work. If not, return it.
Go for 900 or 1200 TV lines, a 1080p won't work on the BNC.
Re: BNC Camera
Posted: February 27th, 2018, 10:51 pm
by SanJuanDreamer
tomschauer, good idea....now I realize it would need to be 12v.
Camera in the engine room is not looking good...
Re: BNC Camera
Posted: February 28th, 2018, 5:24 am
Tom....can you explain what you mean there....I am trying to learn more about these cameras also.....thanks.
Re: BNC Camera
Posted: February 28th, 2018, 8:40 am
by tomschauer
Camera picture quality is rated in TV lines, 400,700,900, 1200 an then 720p, 1080p HD. The higher the number the better the resolution.
Most of the 720 and 1080 will not be compatible with the BNC cables and connectors.
The camera comes with a 120vac-12vdc power supply. So, just remove the transformer and connect to a fused 12v power supply on your boat.
Re: BNC Camera
Posted: February 28th, 2018, 8:55 pm
by SanJuanDreamer
Found a 12v Outdoor camera...
I'l lwork that project next....
Re: BNC Camera
Posted: February 28th, 2018, 9:08 pm
by tomschauer
As far as I know they are all 12volt. Most come with a 120vac to 12vdc power supply.
Re: BNC Camera
Posted: February 28th, 2018, 9:28 pm
by Lyndon670
I have this camera attached to the "video in" on my Garmin. Works perfectly. I just tossed the small screen once I bought it.
http://www.4ucam.com/Wireless-Backup-Ca ... ision.html
Re: BNC Camera
Posted: March 1st, 2018, 11:42 am
SanJuanDreamer wrote:Source of the post My Garmin 741xs has a BNC connection for a camera.
Apologize for the sidetrack.....how has your experience been with the Garmin 741 itself ?
Re: BNC Camera
Posted: March 1st, 2018, 12:28 pm
by SanJuanDreamer
Bud37 - I've had it for about three years, have had no problems with it.
Purchased the Garmin 741xs Combo, which included the 18HD Radar.
Garmin keeps up with OS software updates and a person can buy the map updates.
If I did it again, I would look for a bigger screen.
