Shower Sump
- Danpmart
- Vessel Info: 1997 355 AC
- Has thanked: 18 times
- Been thanked: 3 times
Shower Sump
I have a 1997 355AC and the shower sump is not working. Checked with a volt meter and I'm not getting any power. I reset all of the breakers and they all appear to be working. Is there a switch or GFCI that the pump may be wired to? We had a bunch of kids on the boat yesterday so anything is possible..
Thanks,
Dan
Re: Shower Sump
- Danpmart
Re: Shower Sump
Viper wrote:Source of the post If you have power after the breaker, there should be power at the sump unless there is a break in the wiring or bad/loose harness plug if applicable. Are you sure there isn't power there and it's just a faulty float switch or pump?
I checked it with a volt meter. I'm not getting anything to the pump. I even made a fresh cut inside the Sleeve and tested it there.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Shower Sump
Re: Shower Sump
- Cooler
Re: Shower Sump
Re: Shower Sump
Re: Shower Sump
Re: Shower Sump
Users browsing this forum: Google Adsense [Bot] and 15 guests
