Potable water tank on a 530 Voyager
2000carver
Vessel Info: 1999 Carver 530
Postby 2000carver » May 11th, 2022, 4:20 pm
We have 2 potable water tanks on this boat, however when I fill it up only one tank fills. Ant ideas on how to fill the second tank?
Re: Potable water tank on a 530 Voyager
Postby tomschauer » May 11th, 2022, 9:29 pm
I don't have a voyager, but if you have two tanks, you most likely have two separate deck fill ports.
Sgodfrey
Vessel Info: Carver 450 Voyager
Been thanked: 9 times
Postby Sgodfrey » May 12th, 2022, 2:50 pm
On the voyager 450 there are two tanks (out board of the engines) - single deck fill and the two tanks are connected together via pipes. I have never investigated how they are connected but we just have one fill that properly fills both tanks.
Alaska 530 Voyager
Has thanked: 42 times
Been thanked: 36 times
Postby Alaska 530 Voyager » May 12th, 2022, 6:50 pm
That's correct, one fill on stbd side. There is a crossover pipe thats not easy to access. I would check the vent on the empty tank. Possibly clogged not allowing the air out so the water can cross over.
denders
Vessel Info: 1985 Carver 3607 Aft Cabin
Has thanked: 2 times
Been thanked: 24 times
Postby denders » May 13th, 2022, 8:25 am
I second Alaska 530 , we had issues filling the 2 tanks on our 3607. Cleaned out the vent lines and things went much better.
