89' Santego switch to raw water flush
bobwhorn
Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
Has thanked: 3 times
Postby bobwhorn » January 31st, 2024, 5:04 pm
With the small water tanks, I think it is a shame to use fresh water to flush the head. There is an unused thru hull next to the shower sump. Has anyone used that thru hull for flush water?
Bob
Re: 89' Santego switch to raw water flush
Postby tomschauer » January 31st, 2024, 9:06 pm
Your boat may have used that thru hull for the raw water flush when new, someone probably changed it over to freshwater flush to eliminate smells and nasty dirty toilet bowls.
If the head was also changed, it may not have an onboard raw water pump, so you need to check that before considering changing.
bobwhorn
Postby bobwhorn » February 1st, 2024, 10:05 am
I figured I would need to add a pump.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » February 1st, 2024, 7:21 pm
That’s where my raw water comes in to flush the head.
Ron
“Escape Plan”
Murray, KY
:usa:
Users browsing this forum: No registered users and 117 guests
