A/C compressor issue
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
What I have found... When i turn the unit on everything seems to work as normal, the fan comes on, I then hear a click and the water pump starts and then I hear a click for the compressor, however the compressor does not start. Water flow is good, and there is no air handler blockage. I have ran both a low and high pressure switch test at the controller and both report ok and no errors. From what I understand, it the unit is low on freon, I should get an error from the low pressure switch. I also did a system reset at the controller, but no change in condition.
It problem appears to be related to the compressor, does anyone have an ideas on what to look for next?
“Escape Plan”
Murray, KY
- Been thanked: 1114 times
Re: A/C compressor issue
But also clarify one thing in your OP... in the first paragraph, it sounds like when you reset it then it will run OK for some time and then stop working, but the second paragraph is sounds like it's not working at all now.
- Has thanked: 474 times
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 197 times
- Been thanked: 55 times
1999 Carver 406
