Black Water Tanks Carver 500
Jdamon71
Vessel Info: 1997 Carver 500
Postby Jdamon71 » October 13th, 2025, 10:29 am
Hi All ... I have a 1996Caver 500 CPMY and for the life of me cannot find the aft Black Water tank. I have found the Vaccu Pump, which sits under the floor in the owners cabin by the shower and tried to follow the pipe forward but loose it. In the Engine Room I Daylighted a waste pipe going aft through the stringer on the stbd side however I do not see a tank in the engine room. One thought was there is only on tank forward, but I do not see how that is possible with only one input and one output on the fwd tank. I have looked everywhere I can think of, even under the panel of the aft berth but only found the AC. HELP!
Thanks in Advance!
Jon
Catherine M
Carver 500
Portsmouth, NH
Been thanked: 1114 times
Re: Black Water Tanks Carver 500
Postby km1125 » October 13th, 2025, 8:50 pm
Likely two tanks, but I don't know that model. How many pump out fittings are on the deck?
Jdamon71
Postby Jdamon71 » October 14th, 2025, 8:32 am
One.... But a y valve in the engine room.
Thedingoguy
Postby Thedingoguy » December 3rd, 2025, 7:14 am
Hi Jon. The tank is sort of under your central vac area. Pull the mattress from the platform in master. Below the headboard there are a couple of lift-out hatches and the aft portion of the black tank (and the hoses) are accessible
From there.
Ken and April.
1998 Carver 500
