Rule 3700 sump bilge air lock
Posted: January 5th, 2015, 6:55 pm
Hello: I have a Carver 530 Voyager and have an issue with my sump box bilge pump. It seems to get an airlock and continuously run not sucking up any water. It works fine while at dock or at a very calm anchorage. Basically, while sitting at the dock, the water in the sump box remains low and level, switch is only on with incoming grey water. Nothing to pump unless the float is tripped from incoming grey. Head out to sea, the same amount of low water remaining sloshes indicting more water than is actually there, the float switch turns on the pump, and the pump sucks up water and air until it stops sucking up water for some reason (the air it sucks up creates and airlock possibly?) It then runs continuously without sucking up any water. When we get back to the dock we can take a shower and the sump box fills up and overflows even with the pump running (it's running but not sucking up water). I then disconnect it (cut a power wire) and then reconnect it and it works fine.
Any suggestions?
Thanks in advance, Bob
Any suggestions?
