Discharge leak from AC Carver 466
Posted: April 17th, 2016, 8:04 am
Unusual one... I have an 04. 466 Carver with a fifth aftermarket AC unit installed behind the aft deck refrigerator , but that is not the problem. It works fine, however, when I turned on the aft CABIN AC Unit at spring start up I found seawater leaking into the condensation pan of the aft DECK AC unit which then overflows into the salon sliding entrance door Gunnel which has an overboard drain. This isn't a slow leak. It sound as if there may be a line that has come off. But I can't understand the connection between the two units as they are completely separate other than sharing a common sea pump. The sea pump has a five outlet spider manifold , separate feed to each AC unit. How can the AFT deck condensation pan be filling whe I turn on the Aft CABIN AC? I don't see how they could be conjoined with one another
