2001 Carver 444. AC
Posted: June 30th, 2018, 7:10 pm
by Tomion
My Fwd AC is doing some Bizarre things that is orobably the controller as they seem to go bad regularly.
The AC will sometimes run well for hours cooling nicely. Then the fault cycle begins.
The heat comes on and the display starts cycling thru single numbers. The AC condenser is not frozen over!
Today is ran fine awhle and then quit and displayed a fault code of HPF. Of course that fault code is not in manual.
The other two ACs work fine and water pump is working.
Re: 2001 Carver 444. AC
Posted: June 30th, 2018, 11:24 pm
by g36
Hpf. Is high pressure fault or a high head pressure on compressor. Could be issue with air flow, waterflow or compressor. Don't know what brand ac you have so maybe put up more info.
Posted: September 8th, 2018, 12:51 pm
by Tomion
I spoke to Temtec formily Marine air and they recomended cleaning elctrical connections and doing a software reset. Neither if which solved problem. I surender, Mechanic brung new controll board and high oressure switch Monday
Posted: September 10th, 2018, 4:35 pm
by NickElliott444
Good luck with the repairs. I just bought an 01 444 and am looking for a manual/owner's guide. I cannot find one online. Do you know where I may find one?
Thanks!
Nick
Posted: September 10th, 2018, 5:42 pm
NickElliott444 wrote:Source of the post Good luck with the repairs. I just bought an 01 444 and am looking for a manual/owner's guide. I cannot find one online. Do you know where I may find one?
Thanks!
Nick
Welcome to the forum, Nick....try an e mail or call to Carver....doesnt look like one is available on their site..
Posted: September 12th, 2018, 1:25 pm
by Tomion
I will photo copy mine and send it to you. I need your address.
Posted: September 12th, 2018, 1:34 pm
by Tomion
Send me your email and I will scan mine and email it to you.
tomion12@gmail.com.
Posted: September 14th, 2018, 5:54 pm
by Tomion
Ac repairman installed remote remp sensor and had simialar problem. Ordered a control circuit board. These circuit boards sure are garbage. That 3 in 3 years fir me.
