Carver 33/35/36ss head fill solenoid/valve??
Posted: January 1st, 2022, 12:22 pm
by danclev
Hey guys,
The head kept filling after flush, now won't stop filling. Checked switch, seems to be ok. Had to unhook the supply hose and plug it while I troubleshoot.
Has anyone had this issue or do you know/suspect the culprit? I can't find the solenoid/valve that controls the flow either.
Thanks!!
Dan
Re: Carver 33/35/36ss head fill solenoid/valve??
Posted: January 1st, 2022, 12:37 pm
by buster53
What brand/style of head? Fresh or sea water flush?
Posted: February 12th, 2022, 8:51 am
by danclev
It is a freshwater flush.
Posted: February 12th, 2022, 9:13 am
You never said what brand the toilet is.....anyway there is a solenoid controlled by the flush switch.....on some brands/installs the valve is located in the back of the toilet in the fresh water feed line....you will have to see behind, try a mirror and light.
Look on line for a parts schematic/manual for the brand toilet you have.....good luck man.
Posted: February 24th, 2022, 9:00 am
by JohnS
Posted: August 28th, 2022, 4:09 pm
by danclev
A quick update : the solenoid valve is located BEHIND THE REFRIGERATOR on the Carver 33/35/36 SS of all places. Took two people to slide it out and tip it forward enough to reach the valve. Sure enough there was a flake of plastic keeping the solenoid open. Cleared it out and good to go now. Here is a video of the instruction on how to open the valve and clean it out. Took 5 min once I got to it.
