2003 Mariner Water Level Gauge & Sender
Posted: February 6th, 2022, 11:03 am
by JohnS
Gauge only moves from 3/4 full to 1/2 full, does anyone know the brand of these?
Any info would be appreciated.
Re: 2003 Mariner Water Level Gauge & Sender
Posted: February 6th, 2022, 11:22 am
Pop the blue cover off and see if there are some very small adjusting screws there.....there may be one for full and one for m/t if that is the same as the one I had, perhaps they have some corrosion and need to be exercised. With ours it took some fooling around as they are quite sensitive.
Posted: February 6th, 2022, 5:51 pm
Also check your connections and ensure they're clean and tight. You may also want to pull the sender and check to see if there is anything impeding it from acquiring a proper level. It might just need a cleaning.
