Carver 355 forward head leak Vacuflush
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Carver 355 forward head leak Vacuflush
Check the toilet fittings and check the holding tank to see if any damage from collapsing due to pumpouts if there is no tank saver fitting. Do you have overboard discharge ?
- Bentone23
- Contact:
1996 355 Aft Cabin
Central California
Carverlvr2
- Vessel Info: 2004 Carver 366, VP 8.1’s
1979 Searay Sundancer 260 - Location: Shelbyville, IL
- Been thanked: 25 times
- Been thanked: 1113 times
That said, finding out what actually occurred needs to happen after cleanup is done. THEN you can figure out the next steps in making it all work correctly again. Don't just guess at what the PO might have done.
I didn't see an answer to bud's earlier question ("Do you have overboard discharge ?"), but that could be a clue if the discharge pump got inadvertently activated into a closed discharge valve.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
Trouble shoot the liquid level guage once you pump out the holdiding tank.
