Inverter ideas
Seif911
Vessel Info: 1977 Carver Mariner 33'
Been thanked: 4 times
Inverter ideas
Postby Seif911 » May 27th, 2013, 9:10 am
Good Morning All,
I am curious how everybody has a inverter setup on their boats. In my breaker box I have a breaker for shore power and one for the generator. I could set up an inverter going to the breaker box, but I guarantee that one of my kids will mess up the thought, like leave the inverter on when connecting to shore power. Very bad...
I need to make the above scenario impossible. Since I am in the marina, I most likely will not need lots of power for anything but a tv/DVD. I think I can just leave the frig off for a day trip of fishing/diving. I was thinking of maybe mounting the inverter and just using the outlets directly off of it to power the tv/DVD. If we need the microwave or something larger, I can always crank up the generator.
Thoughts or comments? Is this really my best option? I have 11 kids...and we all know kids. Everything they can touch or play with, they will.
Thanks,
Steve
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Inverter ideas
Postby AaHubb » May 27th, 2013, 11:03 am
That's what I have for a setup. I mounted the inverter near the batteries to keep the heavy gauge 12v cables ($$) as short as possible. I then routed the 120vac to a power strip behind the tv.
'99 404 CPMY
SeaDragon
Has thanked: 58 times
Been thanked: 470 times
Re: Inverter ideas
Postby waybomb » May 27th, 2013, 11:11 am
11 kids? Eleven? Dude, you need a 65 Hatteras!
I guess I don't understand why you would bother with an inverter? You have a Genny for trips, and every marina on Lake Michigan has standard shore-power connections. I'm plugged in whenever not out on the lake.
Seif911
Re: Inverter ideas
Postby Seif911 » May 27th, 2013, 3:04 pm
Hmmm...a power strip behind the tv just to the inverter, I like it.
Ya...I really only need it when I am actually fishing. The kids may find fishing boring and it will entertain them...how sad is that!
Thanks,
Steve
Re: Inverter ideas
Postby waybomb » May 27th, 2013, 4:59 pm
Make sure you use your battery switch each time, so you can restart the engines!
Seif911
Re: Inverter ideas
Postby Seif911 » May 27th, 2013, 6:48 pm
True. I also have a 3rd battery just for the generator. Of course the problem is that I did not connect any wires to it except for the charger so I always have a spare...no not the plan, just too much to do.
Thanks,
Steve
Eddie Ziegler
Vessel Info: 2000 530 pilothouse
Re: Inverter ideas
Postby Eddie Ziegler » September 9th, 2015, 10:01 pm
I have to leave my invertor
breaker on to run my fridge and freezer when I am on shore power are the generator is this correct?
Re: Inverter ideas
Postby waybomb » September 10th, 2015, 9:20 pm
An inverter will take dc current and turn into ac current.
If you are on shore power or genny, you already have ac available, so no need for the inverter.
Return to “Electrical”
