1993 440 aft cabin inverter location
Scubabubbles
Vessel Info: 1993 carver 440 aft cabin
Has thanked: 5 times
Postby Scubabubbles » June 27th, 2025, 8:38 am
Hello everyone!
Can anyone tell me where i can find the stock 600w inverter? I don't see a breaker for it on the panel so i'm not even sure there's one installed.
thanks!
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 284 times
Re: 1993 440 aft cabin inverter location
Postby buster53 » June 27th, 2025, 9:46 am
Since I’ve never had an inverter, I’m no expert, but I’m guessing you would have to have some kind of breaker or transfer switch if you had one. Are you able to run any kind of 120v light or appliance when not hooked to shore power or running your genset? Probably not. Why do you think you have one and if you did, 600 watt isn’t very big
Been thanked: 646 times
Postby g36 » June 27th, 2025, 10:07 am
If carver had installed it theinverter breaker in the electrical panel will have one there. The oem inverter on my 405 was by the electrical panel underthe dinette. The only thing it was installed for was for the "home style audio equipment " 600watts isn't much. So if you don't have that oem audio that's another chance you probable don't have one. I've since moved on with removing that puny inverter and installed another and for other things in the boat.
Has thanked: 78 times
Been thanked: 1095 times
Postby km1125 » June 27th, 2025, 2:40 pm
I don't remember which model it was, but recall someone having an OEM inverter behind a panel behind their TV in the salon.
buster53
Postby buster53 » June 27th, 2025, 4:54 pm
km1125 wrote:Source of the post I don't remember which model it was, but recall someone having an OEM inverter behind a panel behind their TV in the salon.
That sounds reasonable. It could be dedicated only to the TV with no breaker or transfer switch. TV runs off 12v power only.
Return to “Electrical”
