Master Breaker Panel 1997 Carver 405
Posted: October 8th, 2015, 2:03 pm
by Wayne162
I am unable to get shore power to the right half of my main panel controlling the AC and AC pump. The left side for everything else shows 120 and is all good. When on ship power, everything works fine on generator. This problem just started last week. The marina noted that the power on the dock is fine. I have checked the breaker in the main box and found the right side tripped. The breaker at the stern was checked and appeared on. It was reset but nothing happened. Any ideas?
Re: Master Breaker Panel 1997 Carver 405
Posted: October 8th, 2015, 4:57 pm
by waybomb
Check the cord - try a different one.
Next I'd pull the connector out of the bulkhead and check the connections on the back side.
Posted: October 8th, 2015, 10:08 pm
by Wayne162
Thanks, will do and let you know.
Posted: November 2nd, 2015, 8:50 pm
by Wayne162
Slow in my follow-up but the problem was in the marina wiring. Moved to my new slip and power was fine on my end.
Posted: November 3rd, 2015, 12:02 pm
by waybomb
Glad you've been energized...
