Page 2 of 2
Re: Courtesy light 1997 355
Posted: August 6th, 2018, 4:00 pm
by cpoint
I had done that a while ago, which same on my 356. I just broke it and replaced all with same type inside (floor) and out side ones. here are couple pics, unfortunately I did not have a pic of the one you mention by outside door and above deck, will post them later. I went with blue on all above deck and inside floor, Including the 2 white ones on aft deck ceiling.
Posted: August 8th, 2018, 7:38 pm
by fleck05
When I lose a light I usually go to WalMart, get one of those $3 sensor lights that operate off a couple AA batteries, and stick it next to the dead light. At some point I'll need to run some wire, though... my AA battery bills are getting a little high.
Posted: August 8th, 2018, 10:03 pm
by buster53
While a new fixture would be nice, I just want to replace the bulb with an LED. Any problems with replacing the bulb I need to know about?
Posted: August 9th, 2018, 12:31 am
by cpoint
just get the bulb number you are replacing and search for same on the web. I usually get the lights/bulbs from either eBay or Amazon. I did initially replaced the bulbs on the ceiling (cabin) lights with led bulbs, while they were cooler than the originals, which used to get very hot, I ended up replacing with pod led lights from super bright led site at $9,95 each. they were pretty good fit, looked great and do not get hot. For stairs and deck (inside/outside) I also tried out led bubs, but got a good deal on 3 led blue lights with chrome around, got about a dozen almost for the price of the bulbs under Amazon. If you are getting the bulbs, make sure the size will fit where you are installing. some of the led bulbs I noticed may be slightly bigger then the non-led version of same number.
Posted: August 9th, 2018, 6:10 am
by tgmkwill
I use this place to replace any g4 old bulb with new led lights in the ceiling ring fixtures. The prongs on the new LEDs are just a little bit thicker, just use some dilectric grease on them and they can be pressed into the original socket.
https://www.superbrightleds.com/cat/led ... al-finder/Nice job on the inside courtesy lights. Also I like the flooring.
I kept the fixture I pulled out, I just pulled out the halogen light and wired this little blue light( link below) into the old bulbs place. Put the original light cover back. This blue led is about the size of a nickel. Fit right inside the old fixture.
https://www.westmarine.com/buy/west-mar ... R9EALw_wcB
Posted: August 10th, 2018, 9:32 am
by buster53
buster53 wrote:While a new fixture would be nice, I just want to replace the bulb with an LED. Any problems with replacing the bulb I need to know about?
Well, I pulled one of the sockets out of the wall to remove the bulb so I would know what type LED replacement bulb to buy. Anyway, the socket is so small, my fingers won't fit to pull the bulb out. Any suggestions
Posted: August 10th, 2018, 11:55 am
by tgmkwill
If you squeeze and pull the black rubber part I circled in pic , that part will separate from the plastic shroud that covers the bulb. The bulb is "wedge" style instead of two prongs going in to the socket. Only way I know to get that bulb out, I even had my wife to try remove the bulb with her small fingers before I just pulled the hole fixture out. She couldn't do it with out squeezin the bulb so hard that it might break.
Posted: August 10th, 2018, 12:09 pm
I love the one pic there with all the tools out, reminds me of what happens quite a lot .....why does a seemingly simple thing turn into getting out half the toolbox...
Posted: July 3rd, 2019, 10:01 am
by Bandit
Has anyone found an LED step light to replace those pictured by tgmkwill with same bolt pattern? My plastic fixture is melted.
Also looking to replace my outer hooded deck lights
