Page 1 of 2
Anchor light bulb
Posted: August 1st, 2020, 1:17 pm
by Mike11
I just purchased a 1997 Carver 350 Mariner and the anchor light bulb is missing from the pole on the arch. Anyone know what size the replacement bulb is and where I might get one. Thanks for any advise. Love our new to us boat!
Re: Anchor light bulb
Posted: August 1st, 2020, 2:56 pm
by buster53
When you find out what kind of bulb you had, make sure you replace it with an LED equivalent.
Posted: August 2nd, 2020, 9:11 am
by mjk1040
Most likely a single contact 12v bulb with 2 side pins across from each other any auto store would have one, but as stated by buster a LED replacement would be your best choice.
Posted: August 2nd, 2020, 10:18 am
We can't assume the fixture is the original one so the brand and model would help for sure. A picture of the inside where the bulb goes would help, some are screw in, some are twist on, some are festoon. If it's a Perko fixture, they have LED replacement bulbs for some models but really, there are LED bulbs for just about all bulb types these days. What you want to ensure is that it meets coast guard visibility requirements for your area like 2 nautical miles for example, some areas may be more. This might help you narrow down the brand and model....
https://www.google.com/search?q=boat+anchor+light+pole&tbm=isch&ved=2ahUKEwjG7sfj2vzqAhWGBt8KHe4vAdIQ2-cCegQIABAA&oq=boat+anchor+light+pole&gs_lcp=CgNpbWcQAzICCAA6BAgAEBg6BggAEAUQHjoGCAAQCBAeOgYIABAHEB46CAgAEAcQBRAeOggIABAIEAcQHjoECAAQHlDVIlipeGCbfGgAcAB4AIAB2AGIAfURkgEGMC4xNi4xmAEAoAEBqgELZ3dzLXdpei1pbWfAAQE&sclient=img&ei=1MomX8a0IoaN_Abu34SQDQ&bih=608&biw=1229
Posted: August 2nd, 2020, 7:58 pm
by denpooch
I was 'on the hook' a couple of weeks ago and noticed that the anchor light was not working. It was a strange looking torpedo type of bulb and there are 2 per fixture. I believe they are wired in 'series'; if one fails, neither will work. They stocked it at my local marina but did not have LED version.
I did find an image online of the LED version.
http://i.ebayimg.com/images/i/291523815 ... -l1000.jpg
Posted: August 2nd, 2020, 8:28 pm
Those are called festoon style bulbs. DP, I suspect you have what's referred to a masthead/anchor light as apposed to an all-around light. The all-around night has only one bulb that turns on for running and at anchor. Yours should have a switch when in one position one light turns on (front) and in the other position both lights turn on as required to be at anchor. A lot of guys will hook up both sides (bulbs) so that both bulbs are on no matter the position of the switch as that suits navigation and being at anchor. The front bulb on only is for navigation while underway. Usually this is accompanied by a stern light as well, usually on the transom but a lot of boats don't have that.
Posted: August 3rd, 2020, 10:43 am
by Mike11
Appreciate the info. Attached is a pic of the unit minus the bulb.
Posted: August 3rd, 2020, 3:59 pm
by buster53
Never seen anything like that before. If I had to make a guess, I would say you need a festoon bulb. Just measure the distance between those contacts and buy the bulb to fit it.
I've bought LED equivalents for festoons, but they did not give 360 degree lighting. That could be a problem looking for LED's.
Posted: August 3rd, 2020, 4:01 pm
by buster53
What about just changing the whole fixture? Not crazy about that fixture.
Posted: August 3rd, 2020, 5:03 pm
That's a strange one for sure. It looks like it would be a festoon type but not in the traditional sense as there's no way it would stay in place. Looks like it would take a festoon with dimpled ends to accommodate the dimples on the fixture's contacts. The only thing that comes to mind is the long halogen type bulbs you find on an outdoor motion detector light in the driveway, they are about 3" long with dimpled ends on them. The other one that comes to mind is a festoon type who's end contacts are loops that would fit under the bottom contact and over the spring loaded top one. The dimples would help keep the bulb from sliding off. Not exactly what I'm talking about but something like this...
http://www.nicebulb.com/Automotive%20LED%20bulb/Led_Festoon_Bulb/2018/0925/261.html
I would consider going with a more modern LED fixture too. You can buy that same type that will mount on the current bracket and not have to worry about replacing a bulb again for a long time.
BTW you can get all-around LED festoon bulbs now.
