USB Outlet Options
Posted: August 7th, 2020, 7:53 am
USB is changing and getting more powerful, charging laptops and quick charge on many phones not to mention USB-c which seems to be slowly taking over as the norm. I converted a few of my 12v outlets to standard USB several years back however the power output is not up there with todays standards so I went shopping for todays stuff.
If you are an Apple fan the you will want PD USB-c units which stands for Power Deliver. This charges your phone or laptop at 9v or 12v as opposed to 5 volts yet can deliver standard 5v to any device plugged into it. There is also a similar standard USB type which is referred to as QC-3.0 (Quick Charge)
That being said here is what I have installed replacing exiting 12v outlets, 110v outlets and simple plug-in adapter to supply USB power.
Drop in replacement for 12v power socket. https://www.aliexpress.com/item/4000274 ... 4c4dYypc3q
110v receptacle which replaces your existing receptacle however do keep in mind this does not function when away form shore power unless the genny is running. https://www.amazon.ca/gp/product/B07M87BM96/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Compact plugin 110v multiport. https://www.amazon.ca/gp/product/B07TTGPPBF/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
