Page 1 of 6
Electrical
Posted: November 12th, 2021, 2:42 pm
by Charleigh
I just purchased a 2005 56 voyager. It is going into storage for the winter and the spot only has 30 amp power. I tried a 30 amp 125 to 50 amp 125/250 adapter with no luck. What do I need
Re: Electrical
Posted: November 12th, 2021, 3:37 pm
What didn't work?
Anything that's 240VAC won't, but you should be able to power 120VAC stuff, at least one side of the panel.
Re: Electrical
Posted: November 12th, 2021, 5:32 pm
by Tireless
A friend of mine requires 240 as well as myself. He built an adaptor/pig tail that has two 15 amp male ends and a 50 Amp end that he plugs into the boat in a “Y” configuration. He runs an extension cord from each 15 amp male end to 15 amp wall plugs on a different phase. The boat then gets the 240 that it requires and will run fridge, battery chargers and small stuff like that under 15 amp draw.
If you have a twin 30 amp to 50 amp “Y” adapter, it will also work. I use this at the dock when a 50 amp is not available, such as my case at my home slip. Both of these 30 amp plugs must also be on a different phase for it will work. I have run into problems when travelling, trying to use my twin 30 amp to 50 amp adapter when the 30 amp posts are all on the same phase. I have to check a number of posts to fine one on a different phase to get 240.
One simple 30 amp to 50 amp will not work as the boat is only receiving 120 and not 240.
I hope this helps you out.
Greg
Re: Electrical
Posted: November 12th, 2021, 5:35 pm
by Tireless
km1125 wrote:Source of the post What didn't work?
These boats must have 240 coming in or nothing will work not even one side of the panel.
Greg
Re: Electrical
Posted: November 12th, 2021, 10:26 pm
You need a "Reverse Y Adaptor". Like Greg said, the two 30 amp plugs must be plugged into different legs/phases or it won't work. If you can't get that out of one pedestal, you'll have to plug one in your pedestal and run a 30 amp cord to extend the other side to another pedestal that's on a different leg.
https://www.marinco.com/en/p/RY504-2-30/Reverse-Y-Adapter-2-30A-125V-Males-to
Re: Electrical
Posted: November 13th, 2021, 12:07 am
by Charleigh
Thanks for the information. I didn’t realize that nothing would work if 240 volt wasn’t applied.
Re: Electrical
Posted: November 13th, 2021, 3:31 am
by Midnightsun
I went through the same thing when I purchased our Carver. It's 240v or nothing. Not every practical when on the hard as 240 is usually difficult to find.
Re: Electrical
Posted: November 13th, 2021, 10:57 am
I'm not sure I'm understanding the problem here. Does anyone have the AC wiring diagram from one of these "240" boats that I could look at so I could understand where the problem is?
Re: Electrical
Posted: November 13th, 2021, 5:28 pm
by buster53
Not an electrician but as I understand it, 240 comes into the boat and it is split into 2 x 120, but you have to have 240 to make it work.
Re: Electrical
Posted: November 14th, 2021, 10:44 am
buster53 wrote:Source of the post Not an electrician but as I understand it, 240 comes into the boat and it is split into 2 x 120, but you have to have 240 to make it work.
If the incoming cord was only a 240 that might make sense. You'd need a transformer on board though, which a lot of boats don't have. If the incoming is 120/240 then it shouldn't be an issue.
The difference is the neutral connection. The 120/240 plug has a neutral connection but the 240 only does not. You'd need the transformer with a split secondary to establish the neutral (and bond it to ground). That would give you two 120's out of the 240.
