Building a sofa for Carver 355
Sailor Jerry
Vessel Info: 1996 Carver 355
Has thanked: 2 times
Been thanked: 8 times
Postby Sailor Jerry » May 26th, 2020, 5:43 pm
As you know, the original Carver sleep sofa has to be moved for access to the port engine. That sofa was just too much for me to handle. I would have to partially disassemble it to move it when doing maintenance. Plus after 20 years it was showing some wear. I would have loved simply purchasing a sectional unit, but could not find one the right size. I decided to build a sectional. No, I have never built furniture before. I studied some sectionals online, example: https://www.homereserve.com/?show=secti ... WwQAvD_BwE
I started back in January. The wood frame is 1/2 exterior plywood. I made the legs out of poplar (which stained very close to the teak interior). There is more storage than with the original, and I left the bottom out of the 'L' so its easy to get to the gas valves. One thing I would do differently, I bought firm polyfoam from Walmart (online). I would order regular density, because to me, its a little too firm. If anyone wants the dimensions and rough diagram, just email to jerrygaggini@aol.com
Re: Building a sofa for Carver 355
Postby Midnightsun » May 26th, 2020, 6:14 pm
Wow, nice job. :down: :down:
Danpmart
Vessel Info: 1997 355 AC
Has thanked: 18 times
Been thanked: 3 times
Postby Danpmart » May 26th, 2020, 10:38 pm
Awesome job! :clap:
Postby tomschauer » May 26th, 2020, 10:46 pm
looks pretty slick!
If your gas valves are under the "l" i could see you had a problem as that L is a pain to move. They must have improved the 355's as my 98' has the fuel selectors ( i assume that's what you mean by gas valves) forward of both engines in the center of the boat, just pop up the center hatch and they are actually easily accessible.
Been thanked: 470 times
Postby RGrew176 » May 27th, 2020, 9:02 am
Looking good. Thats one way to make accessing the engine compartment a bit easier.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » May 27th, 2020, 9:32 am
Great work! Sweeeeet! :down:
Ron
“Escape Plan”
Murray, KY
:usa:
Sailor Jerry
Postby Sailor Jerry » May 27th, 2020, 11:10 am
Thanks guys for the positive feedback. It did turn out nice. With the new wood blinds, new carpet and high gloss varnish on the woodwork, the old boat looks pretty good.
Postby bud37 » May 27th, 2020, 11:33 am
Good job, looks nice, great idea having it in sections that are easily moved around....it will pay off big time.... :down:
Postby RGrew176 » May 28th, 2020, 9:26 am
A true sectional sofa.
