Change transmission fluid?
Posted: February 17th, 2017, 9:07 pm
by Bankerbiz87
Where is the dip stick located on our 1981 Carver with V Drives we want to change the trans fluid Thank you!
Re: Change transmission fluid?
Posted: February 20th, 2017, 3:22 pm
by mjk1040
Thinking it should be a T handle rubber plug type with a dip stick attached. Should be on the transmission its self. If your sitting between the engine I believe they would be on the right side of each transmission. Mike
Posted: February 25th, 2017, 7:35 pm
by TonyC
What Mike said is as it appears on our transmissions. Let us know how it goes as I will be changing ours in the next couple of weeks.
TonyC
