Small boat and Titanic same problem!
Posted: June 7th, 2017, 9:50 pm
For those that have seen my post called "small boat big big project", my first shake down cruise last year was a success, but not without exposing problems and items that just need updates or modifications. I have to address list items before my second shakedown cruise this year, at this point I have 25 line items to address, some items are simple such as adding a small table/shelf close to lower helm so I can reach my coffee or binoculars without stretching to my reach limit, the item I am working on now is a little more involved but very important, I need to increase helm authority at slow speeds and in reverse!
The Titanic had a problem just like mine, not enough rudder, in some respects worse then mine. Titanic had one rudder behind the center shaft only, one problem with this that you never see on the documentary shows, is that the center shaft only turned when the ship was going forward using the other shafts, no reverse rotation ever, center shaft was a steam turbine that used the waste steam from the largest steam piston engines ever built to date! Ok so my giant 26 foot yacht has one small Mercury alpha gen 2 outdrive, fine for control at higher speed then I cruise at but not good at very low speeds such as mine. first I have allot of wandering at low speeds unless I put my large trim tabs down, then tracking is fine and no detectable speed loss as a result of tab position as I travel SLOW! I went threw 70 locks last year, I found as I approached the lock walls at slow speeds I had very little helm control and a long delay of what control I did have even with helm hard over.
The plan to fix the problem, first I figured I would just buy a set of Wander fins or Uncle Norms Orca fins to remedy the problem, they get good reviews for fixing bow wander and they help get your boat on plane faster! They are small so they can wok at high speeds. They are a good fit for most normal IO boats but my boat is anything but normal, the original empty weight of the 2667 was about 5400 lbs dry, 6200 with full gas and water, I am tipping the scales at just north of 8100 lbs wet but completely empty, I carry allot of equipment and supplies that adds considerably to this number. Heavy slow and a tiny little rudder, I gotta watch for ice bergs!
I have decided to build my own set of flanking rudders (normally in front of props) for my out drive, similar to wander fins but much larger in every respect, I think this will work fine as my normal cruise speed is 6.1 MPH and max speed of around 9 MPH, I hope it eliminates bow wander so I can stop dragging the back of the boat with the trim tabs ( may get me up to 6.2 MPH
)they should give me allot of helm at slow speeds and should take some load off of the hydraulic autopilot pump! Because of their size I am making them out of 1/4 inch high grade aluminum plate, sorry for all the verbiage but I am long winded! photos to follow soon
thanks
